Online: Stuart
Round Air Cleaner with out stage 1 download or tuner ?
  • Thomo_Baca
    Thomo_Baca
    just get a round cover if you dont want to go with a new backing plate. Take the original off including the plastic at the back
  • Gilbo
    Gilbo
    Is there anyone in Oz that sells the XiED'S/resitors?
  • FatRob
    FatRob
     There are a few around Brisbane so I'd have thought the same would be true down south.
    Let me know if you want to know those up here.
    FR
  • Gilbo
    Gilbo
    East coast customs in QLD is the distributer, ring them and they should be able to put you onto a retailer. Call 1800 101 322.
  • Gilbo
    Gilbo
    No probs, I think I'll end up ordering them direct from Nightrider as well. Let me know how you go with time to your door and what the bike is like after fitting.
