Screamin Eagle Race Tuner
  • cvo06
    cvo06
    Hi edison, Your power module ONLY needs to be taken in to the bike shop if you are going to DYNO tune your bike , Not for a service
  • cvo06
    cvo06
    Every bike is fitted with its own power comander, Coz evey bike is slightly diferent and the module is set to your bikes tune , so if they need to check on something Or re-tune it , They need your module to do that , But its not for your general service ,
  • Rans
    Rans
    Hey Men,
    Is it true that some bikes cylinders can vary up to 15% from each other when they leave the factory.... This was in an old Heavy Duty mag that I read recentley, and apparently the Super tuner smoothes it all out and gets it running sweet, also making the bike run faster, smoother and cooler... Is this true....
  • smeemn
    smeemn
    When my bike was a little off tune they ( the dealer )used the tuner to gather information from a run.They down load it to a computer,change a few set points then down load that to the bike. they call it a smart tune some dealers do it as a part of your service So you should ask if they need it when you get a service.
  • Smick67
    Smick67
    I was told by my dealer that the service dept required the tuner each time I take my bike in for a service.
