Online: John.R, Stuart
What type of glue?
  • Gilbo
    Gilbo
    I just used double sided tape after having my dash powder coated, works fine and hasnt moved after several washes.
  • houli
    houli
    Silastic, non acid type, same as you`d use attaching a mirror, try Bunnings.
  • angry
    angry
    Black Sikaflex. best there is.
  • cm364352
    cm364352
    You can get sikaflex in black or white,use it too glue windscreens in all the time.Great stuff.
    WAZ...
