Online: John.R, Stuart
Engine numbers
  • GTpeter
    GTpeter
    Hey Boys
    Anyone had much to do with changing engine numers in Queensland,just put a S&S 124 kit in my 07 Wide glide was going to use the standard cases but ended up using 120 screaming E cases and they had no numbers stamped on them ,Any info would help.
  • angry
    angry
    you can stamp your old numbers across to new cases[hmmm] and say nothing. or you could go through the hassles of getting new numbers through your local HD dealer. if the engine already has numbers, you only need a reciept forthe engine and  Dept of Trans will do the change over. you can gimme a ring 0449861488 and i should be able to give you a few options. Angry.... Angrys Motorcycle Worx. Kipparing Qld.
