wide glide conversion question
  • ozziepride
    ozziepride
     hi, will a 2003 model dyna wide glide front end fit a 96 superglide frame ?
  • smeemn
    smeemn
    No ! but you can get aftermarket kits
  • ozziepride
    ozziepride
    Gday, so what is the difference ?, why wont it fit?, is there something to modify to make it fit?
    i am aware of after market kits!
    It will fit,,,,,, The only diffrence is the Brake Cailper
  • ozziepride
    ozziepride
    It fits?, cooool , so what needs to be done in relation with the caliper?
  • smeemn
    smeemn
    sorry I stand corrected.cheers
    Twin Cam 2000 and up Cailper have a diffrent Bolt Patern to the Evo 99 and down Caipler
