Raked triple tree problem..HEELP!
  • Bandit
    Bandit
  • smeemn
    smeemn
    Cups will change the trail a good example of this is the V rod ,have a look at the front of one and you'll see.But I don't know if the cups will give you enough (or less).
  • Bandit
    Bandit
  • 07Harley
    07Harley
    G'Day Bandit,
    Wow u certinaley sound like ur having some issues there, mine is more difficult to move around when parking but aside from that it is great bike till 100km/h cruising
    What you need to do is take some measurements and use the rake and trail calculator to see where you may have a problem
    http://www.rbracing-rsr.com/rakeandtrail.html
    Who set up the shocks ? you may have issues there..
    I will be looking into installing raked cups in the next few weeks
    Cheers,
    Chad (07Harley)
  • 07Harley
    07Harley
    I recently fitted a Kurykan Fork brace to my bike, after suffering the ill handling affects from the raked triple tree's.
    I havent had a chance to go for a good ride yet, as it was raining after I fitted it, and im only home every 6 weeks.
    But I rode it briefly down the highway, and through some tight windy bits and was very impressed by the difference it made.
    Cost me around $200 from Rollies Speed Shop.
    Looks the goods too.
    Mine is same as this....
    http://www.google.com.au/imgres?imgurl=http://www.motorcycle-dynamics.nl/i/KURYAKYN-FORK-BRACE_12326.jpg&imgrefurl=http://www.motorcycle-dynamics.nl/search.php%3Fsearch%3Dharley%2520super%2520glide&usg=__9-TBdc9TyB1ecAJi9UWmyZGDWKE=&h=210&w=280&sz=41&hl=en&start=0&zoom=1&tbnid=GsxrJWLfk-iB3M:&tbnh=122&tbnw=173&ei=tJX1TbKBIo3MuAOc2qXFBg&prev=/search%3Fq%3Dkuryakyn%2Bfork%2Bbrace%26hl%3Den%26client%3Dfirefox-a%26hs%3Dpvz%26sa%3DX%26rls%3Dorg.mozilla:en-US:official%26biw%3D1366%26bih%3D675%26tbm%3Disch%26prmd%3Divns&itbs=1&iact=hc&vpx=1101&vpy=232&dur=5268&hovh=168&hovw=224&tx=149&ty=111&page=1&ndsp=29&ved=1t:429,r:14,s:0&biw=1366&bih=675
