Online: John.R, Stuart
Illuminator Pro 3 problem
  • Burnzi
    Burnzi
    Just lost indicators and horn, I have a Badlands Illuminator Pro 3 thingy, this allows me to run LEDs, also turns indicators off after 11 secs and allows hazard lights. (Not available on a 87 model) Any clues to longevity of these??
  • smeemn
    smeemn
    Didn't know the horn was on the same circuit as the indicators. Maybe the circuit breaker is at fault ??Try and bypass the Illuminator the indicators should work if the ignition is on and the engine is not running, horn too.
  • smeemn
    smeemn
    Just a thought ! when you changed the bars and extended the wires mabe some have broken.???
  • Burnzi
    Burnzi
    I think I might have melted the unit, jus found 2 spots where I managed to pinch the rh indicator wire under the strut bolts. Yep not once but twice.......doh. Had a look at their question/trouble shooting guide on the net. Thanks for ur input Smeemn. Cheers Burnzi
