Online: Rextheute2022
Dyno Results
  • Mainey88
    Mainey88
    Put the bike on the dyno the other day coz it was running way too lean,  The surging under light throttle at around 50 to 60klms per hour has gone but still has a surge up to 40klms per hour under very light throttle in 1st or 2nd gear, I can live with this. HP has increased to 81.67 and TQ to 88.03,  how do these figures compare with other 88ci's with 211's and SERT.
    Apparently the early 06 dynas had 8 degree injectors and the later ones had 25 degree ones fitted with a better spray pattern to try and stop the surging problem, on its first service with the mods fitted mine had been tuned for the 8 deg injectors so I was told ????? the popping on decel has all but stopped and I have heaps more power from 3000 upwards.
    Am I warm and fuzzy, well I spent $150 and the bike goes better with a few extra horses to boot so I am happy, but if I do any more mods and need to get her dynoed again I would try a different place just to do a comparison.
  • andij
    andij
    hi mainey have u upprd the compression ,u need more for the 211s .hows the bike handlin now with all new mods , i reckon theres some more ponies in ya bike with more compresson
  • Mainey88
    Mainey88
    Scotty you're a bloody legend man, thanks for going to the trouble of doing all this,,,,, will try and do it myself..................slowly ..........but only way to learn eh.
    Time to start studying the manual, better get some tools now, winter project,,,,, yep will take my time and will keep ya posted.
