Online: John.R, Stuart
handle bars slippin
  • shovelhead1
    shovelhead1
     hey guys , i have a 74 shovel with 1" western bars on it , i have had it for 12 years and all that time the bars keep slowly slipping down towards the tanks  , i have tried new risers and clamps tightened the crap out of them , the bars have a knurl on them but nothing seems to stop them slipping down , has any body had the same problem and found a fix , the only thing i havent done is drill a hole through the bar clamp and fit up a pin , any help would be great , thanks
  • smeemn
    smeemn
    Go for the drill and pin, they won't move then.Just make sure they are where you want them before drilling.
  • AJ56
    AJ56
    The mounting screws on the risers aren't bottoming out are they? That may not allow the clamp to exert its full pressure on the bars
  •  GLEN
    GLEN
    mate you can also try this - go to your local bearing shop and ask for some speed shim (I think thats what its called ) - its the same stuff they use on shafts that are a bit worn to take up the gap between the bearing and the shaft it comes in sheets which you can cut with sissors and wrap around your handle bars - and hold in place with a dab of super glue and then tighten it down - I've done this before and it does work
    ride safe
  • DaveP
    DaveP
    The drill and pin method mentioned is good however if you want to move the positioning later its not so good. Using a centre punch as chopaweezer has suggested around the contact area on the top clamps works really well and should stop them moving, I take it you have chrome risers and chrome clamps with stainless bars? its even worse if thats the case with apes, hit the front brakes hard and you find your face buried in the headlight....
  • Evo
    Evo
    Either pin it or get a set of Burleigh Bars with fixed risers.
  • shovelhead1
    shovelhead1
    thanks boys for the suggestions will give it a try on the weekend , Dave P face plant into the headlight , that made me laugh , not quite that bad
  • smeemn
    smeemn
    Good idea steamer.
  • Train
    Train
    I've heard of the bicycle inner tube as kiwidave mentioned and also heard that you can cut some strips from a beer can, wrap around the bars and tighten down. This works too i've been told.
  • mirkin
    mirkin
    Go for the burleigh bars.
