which pipes
  • jocky
    jocky
    hi guys, iam after a bit of addvice,its probably been discused 1000 times, so hopfully 1 more want matter. anyway,i have 2010 wide glide,with standard headers and cycle shack mufflers,very quiet but once you give it some revs it sounds good,they seem a bit restricted as well.
         anyway i was looking at getting some new pipes v/hines straight shots part# v17819 as i like the look of them,but not sure about there performance as i hear to many people say be carefull what pipes you buy as some pipes hinder performance, some work good, some people say stick with standard headers and change the mufflers.but i realy do want that big beefy sound we all love, so any honest oppinions would be appriciated.
          so my question is what pipes should i get? best for performance&sound......jocky
  • cvo06
    cvo06
    welcome to the forum jocky , I have v&h pipes and you do loose a tinny bit of hp but not enough to worry about  , and yes they sound shit hot , and look good to , so if you asking me ,  yes get them and enjoy...........
  • smeemn
    smeemn
    Super trap two into one, good for that throaty sound and performance with out the ringing in the ears at the end of the day.
  • Soapbox2627
    Soapbox2627
    I have Super Trapp road legend crack pipes, as the name suggests, the sound is a crack rather than a deep tone
  • smeemn
    smeemn
    supertrap with discs
    Your right Jocky, It has been done a millon times. Check out Bassani, All of their Pipes make Great HP and Torque as they are a Steped Header Design.
    Heres the Link to our web site and there is a discount for Forum Members
    http://www.vpw.com.au/category.asp?bike=1&CatID=801
