front indicators
  • kevlad
    kevlad
     any body know where and how much   billet fron indicators are the one that look like a fork clamp  and sit under headlight
  • kingchops
    kingchops
    If you are talking about rellocation kits they are about $60 and fairly easy to fit.
  • Damon
    Damon
    Try these:
    http://www.jokermachine.com/itemstreet2004.asp?ItemID=767&CategoryID=11&Placeholder=0
  • kevlad
    kevlad
    Thanks Damon not exactly what i wanted but a bloody good option cheers
  • WhatTaxi
    WhatTaxi
    is this what ya looking for
  • kevlad
    kevlad
    no they sit between the forks and screw up to the lower fork clamp about 25 mm high with led's at either side thanks anyway cheers kev
