CAM QUESTION
  • nimo07sporty
    nimo07sporty
      HI GUYS IM LOOKING TO PUT SOME CAMS IN MY BIKE BUT GOT NO IDEA WHAT SO EVER IM TALKING ABOUT , SO HERES WHAT I GOT ,
    MY BIKE IS AN 07 SPORTY, GOT TTS TUNER AND SCREAMING EAGLE HEAVY BREATHER AND CURRENTLY RUNNING S&S SLIPONS, BUT I WILL BE PURCHASING VANCE AND HYNES BIG RADIUS PIPES AND WOULD LIKE TO KNOW WHICH CAMS WILL SUIT THE NEW SETUP?
    SO NEW SETUP WILL BE THE VANCE AND HYNES BIG RADIUS PIPES, HEAVY BREATHER, AND TTS TUNER APART FROM THAT THE MOTOR IS STOCK, OH AND ILL ALSO BE PUTTING NEW LIFTERS IN ALSO.
    ANY ADVICE WILL BE MUCH APPRECIATED THANKS.
  • nimo07sporty
    nimo07sporty
    im kinda new to this but why would i need to get new heads? apart from obvious power gains
    i got a 1200 07 with 24000 ks on the clock all mine, im just looking to give it a bit more go and with the pipes and air cleaner combo, im not looking for a total killer machine but iif heads are cheap enough and someone could give me a ball park figure i might consider doing it.
  • nimo07sporty
    nimo07sporty
    ok then so n4 cams has anyone got a part no for them? i usually get all my gear from m&m so need the part no, and where would i search for heads? and what type etc screaming eagle or another brand?
  • nimo07sporty
    nimo07sporty
    yeah i would like it to go like crazy but dont want to spend a fortune on it, i ride mainly around town but do hit the highway also, so im after all round power,
  • skirtster
    skirtster
    Have a look at nrhs performance site,they explain alot about lift,duration,timing,over-lap ect. selection & fitment.In for sale section some-one is selling some sceaming eagle E cams & high pistons .I think sporties after 04 had buell heads & if you put E grind cams which are same as the buells you should have heaps of grunt
