Online: HD17
CAM QUESTIONS
  • nimo07sporty
    nimo07sporty
     HI GUYS IM LOOKING TO PUT SOME CAMS IN MY BIKE BUT GOT NO IDEA WHAT SO EVER IM TALKING ABOUT , SO HERES WHAT I GOT ,
    MY BIKE IS AN 07 SPORTY, GOT TTS TUNER AND SCREAMING EAGLE HEAVY BREATHER AND CURRENTLY RUNNING S&S SLIPONS, BUT I WILL BE PURCHASING VANCE AND HYNES BIG RADIUS PIPES AND WOULD LIKE TO KNOW WHICH CAMS WILL SUIT THE NEW SETUP?
    SO NEW SETUP WILL BE THE VANCE AND HYNES BIG RADIUS PIPES, HEAVY BREATHER, AND TTS TUNER APART FROM THAT THE MOTOR IS STOCK, OH AND ILL ALSO BE PUTTING NEW LIFTERS IN ALSO.
    ANY ADVICE WILL BE MUCH APPRECIATED THANKS.
  • als1200
    als1200
    nimo,  who is doing the work for you?  looking forward to seeing the anwsers on this as my bike is an 06 carbi, which i am sure could do with some also.
  • nimo07sporty
    nimo07sporty
    i would do the cam swap myself but i might pay someone to do the change as i dont want to mess it up, but the local stealer quoted like 800 for the labour 4 hours and new lifters and rocker box gasket sets so mmmm all up id be looking at like a grand just for a cam change and i think its a bit steep
  • 883n Harley Convert
    883n Harley Convert
    Have a chat to ya local indy, let him know what you're trying to achieve and they should be able to point you in the right direction. Not sure whether this will help ya, however it gives a basic overview of the various engine upgrades for the sporties:
    http://www.sportster.org/tech/typical-staged-sportster-engine-upgrades/
  • nimo07sporty
    nimo07sporty
    thanks 883 harley convert but i think ive decided to go nuts lol and turn my 73 cuber 1200 into a possible 88 cube with the lot only cost a few grand for all the parts but im still looking into it and deciding what i want to do, but rather than just doing cams now then wanting more i think ill save up and just do it all in one go
    883n Harley Convert
    Just bought one of these kits and Andrews N4 Cams, waiting for it to arrive @ the moment. Found these guys through a few of the international XL forums and they are supposed to be the ducks nuts when it comes to Sporties!!
    http://www.nrhsperformance.com/ekit8831200.shtml
  • lastoutlaw
    lastoutlaw
    ive found the n4 cams to be much quieter than the 536 cams and much the same really
    can say ive got the 1250 kits from nrhs and well worth it
  • nimo07sporty
    nimo07sporty
    thanks guys but ive now decided to go nuts and possibly do a bolt on full engine kit stage 3, im thinking the 88 cuber kit, has anyone had any experience with these from nhrs? http://www.nrhsperformance.com/ekitsportster04.shtml
    not sure if the link is active but put it in your search engine and have a read and any advice would be very much appreciated, basically now money is no issue il just save up and do it all in one go and make my sporty a fire breathing monster
