mikuni42mm
mikuni42mm
hazy600
any one out there runnin a mikuni 42mm if so does it sound noisey was told that was expected
hazy600
yeah dont no how to explain the noise sounds a bit like a budgie haaaaaaaaaaaa still goes good tho
hazy600
the budgie noise mite b the slide vibrating ur sure can hear it sukn heaps of air to still happy cam an pipes an crane ignition sure complement each other gettn 75 hp
Tux
No budgies, only a large vacuum cleaner! and streched arms.
