Online: Stuart, Hilly
Iron headshake
  • Clement
    Clement
    Guys,
    Do you experience headshake on rough surfaces?
    I seem to get it on the rough tar, not 100% sure if something is actually loose or if this is just normal?
    Any advice would be great.
    Cheers,
    Clem
  • SJ
    SJ
    Yeah I have noticed the same on mine on the last few days. Only a few hundred k's from first service, so I figured they would usually tighten the headstock then.
    I assume new headstocks and bearings would have to seat themselves from new, gain some clearance from that and need a tighten on most new bikes? This is my first new bike.
    How old is yours mate?
  • Clement
    Clement
     mine like yours is spanking new, 430KMs on the clock.
    thanks for sharing.
    Lovin the ride, just so easy and smooth.
    Steering damper can solve that
