Online: Rextheute2022
what to do with brakelight switch wth forward controls?
  • redmond308
    redmond308
    ive ordered a 09 lowrider fxdl  and want to fit aftermarket forward controls [still looking at supreme legends -pro smooth].so my question is because the standard crappy looking hd forward controls have just a bloody long rod to the master cylinder [which is mounted inline with the front of the rear wheel roughly] and the brake light switch screws into the back of the master cylinder, and on the aftermaket units the mastercylinder mounts actually to the forward control, that means the standard master cyl gets removed,how do i activate the brake light?
    is there a perticular brake light switch that should be used?
    is there a hd item that can be used?
    will it plug straight in the dyna's loom?
    any information would be greatly appreceated
    cheers       red
  • Daggs
    Daggs
    dunno can't help you coz mines got the standard crappy looking hd controls :)
    surely whatever you buy will come with everything you need just ask the shop your likely to buy from
