Air Ride Suspension for your Harley-Davidson®
  • chopperworks
    chopperworks
    Chopperworks Legend air ride suspension demonstration.
    This air suspension is the best available on the market today. Adjust ride height on the fly. All you need to think about two little buttons located on your bars one for up and one for down. Simple!
    This system, when used in conjunction with the heartland USA wide tyre conversion could very well be the best thing that you could possibly do to your Harley®.The wide tyre conversion makes it look tough and also makes it practical for second seat & luggage options. The Legend air gives you the ride height for ultimate comfort around town and for those long journeys also when you have a passenger.
    Legend Air Ride Suspension is available from Chopperworks. www.chopperworks.com.au or (07) 3356 6107
  • chopperworks
    chopperworks
    Good afternoon,
    At the moment this sort of set up is about $2300 fitted. add $200 if you want chrome switch unit.
    Hope that helps.
  • smeemn
    smeemn
    That chrome switch is expensive lol
