tru track
  • speed
    speed
     I,ve got a 05 fxd dyna with a 95cu and 10.25 to 1 pistons goes like stink but the problem is i put a wideglide front end on the bike with 3 deg rake and for some reason its started to get shocking speed wobbles .For the last 2 yrs its been fine but suddenly its shithouse i,ve rebuilt the front end ,all good and the arse end is ok ,i cant seem to find the cause of the wobble ,Ive been to a tru track will go a long way to sorting this out ,is there anyone out there that can give me some feedback or ideas Cheers Speed from Coffs
  • homerd
    homerd
    Greetings to you
  • SJ
    SJ
    Hey Speed.
    Cant help ya with tru track but Im sure someone here can.
    The True Track is a great thing to help the rubber mount bike's handle a lot better, but they aren't a bandaid solution.
    If your bike was fine for 2 years, there must be a reason it's started to wobble.
    Find the problem first, then fit True Tracks.
    I've got a similar engine setup, as a matter of interest, what Cam's are you using ?
    Cheers and welcome !
  • BAKES
    BAKES
    G'day Speed
    welcome to the forum
  • cvo06
    cvo06
    welcome to the forum , but dont feed the animals ok
  • Etch
    Etch
    Welcome Speed hope you enjoy the forums, sorry mate cant help you with your problem.
  • robert65
    robert65
    gday speed welcome.
  • motor_head
    motor_head
    Gday Speed and welcome........sorry dude havent a clue what would cause your speed wobbles but i'll put a few idea's on the table : do you have a lower fork brace, if not you may need one, broken frame maybe????? i had a crack in mine near where the gearbox mounted, couldnt see it until the box was removed but hadnt noticed any wobbles, spoked wheels????? all tight and none broken??????
    Post your problem in the workshop section, you will have a better chance of the experts seeing it.
  • scotti
    scotti
    G`day and welcome Speed , Cheers Skin
  • speed
    speed
    211,s bike goes like stink ,blows 96cu,s into the weeds, i,m going to standard rake on the tripple trees hopefully it will take the wobble out of it thanks for the reply
  • jacks
    jacks
    Welcome Speed
  • SoftailSteve
    SoftailSteve
     welcome
  • fattatt
    fattatt
    Welcome Mate hows the tyre?
  • smeemn
    smeemn
    Welcome speed.
