Battery advice
  • Taffymarsden
    Taffymarsden
     Gurus, do you have to disconnect the battery to fit a trickle charger quick connector? Disconnecting my battery (and I guess all bikes of that era) triggers the alarm. Not so handy when the mechanic has to take the battery away and the only way to shut it up is to wait for the back-up battery to go flat.
    And I empathise Muffin. I called in to say a quick hello to a mate last week and left the ignition on (huh???????). Two hours later, get pushing...you sure need a bit of training for that, plus hoping for a bit of the street to be down hill :)
  • cvo06
    cvo06
    well 99% of batteries come from china now just with different labels all nearly the same , so you tell me do i pay double the price for a orig china hd batt or save on a super charge china batt
  • Taffymarsden
    Taffymarsden
     Thanks Fellas.
  • angry
    angry
    on most newer harleys , if you look into your wiring , usually under the seat you will find a very large red or yellow fuse, turn your ignition on, pull this very large fuse , then turn off ignition, disconnect battery and replace, voila, no alarm. dont leave it disconnected for more than a day or 2.to replace, fit new battery, turn on igniton, replace fuse , turn off igniton and alarm should reset.
  • smeemn
    smeemn
    Sorry to hear of your dilemma.This happened to me, ended up changing the regulator,battery and the stator.all genuine though! $$$$$$$ installed them myself.That way I'm good for a few years. then I sold it.lol.
  • smeemn
    smeemn
    Too true.
  • smeemn
    smeemn
    If you have continuity to the engine from the stator its screwed.If you don't then check for around 30 volts AC from the stator when running. If thats ok then its the regulator or the battery thats screwed.
  • smeemn
    smeemn
    Well you can have the volts as well as continuity. But it's the continuity that's screwed.This means the electricity being generated is going all over the bike. Not good, it will charge the battery a little but soon it will fail again. Sorry someone correct me if I'm wrong?
  • smeemn
    smeemn
    Ok sweet.I know where your comming from .lol
  • smeemn
    smeemn
    Thanks Kiwidave .
