2011 streetbob fork problems
  • tiny227
    tiny227
    hi guys, i have a 2011 streetbob with only 100ks on her and the forks are notchy when pulled up and down, i know warrety will sort it but just wanted to see if anyone else has had the problem, cheer Tiny
  • tiny227
    tiny227
    thanks i will check it out! cheers
  • smeemn
    smeemn
    Let the warranty fix it.should be nice and smooth operation.Change the springs and the warranty goes out the door.Better off changing the fork oil to a thicker weight after they have fixed the fault.
  • tiny227
    tiny227
    found the problem and it wasn't the forks when sitting on the bike (not running) and pulling the front up and down i found the notching was actually the front disc which is a floater but very tight so when pulling it up and down with the front brake on', the disc  was moving and giving me the impression that the forks were notchy! alls well now and i saved myself the embarrasment of taking it back to the dealer, you beauty!
    cheers,
  • smeemn
    smeemn
    Good stuff mate ! thanks for the answer to your problem.
