Ikon fork springs
  • SJ
    SJ
    Easy to fit? Never done springs...
    Stock ones are definately suss. City pot holes.
  • Damon
    Damon
    They'll sag by an inch over the first few weeks.
  • SJ
    SJ
    ...and that bad for travel or good for looks?
  • sssmour
    sssmour
    I changed my fork oil as well as the springs. Also dropped the front by 5mm in the triple clamps. Turns into the corners so much better.
  • terroristone
    terroristone
    what oil??
  • Rammo
    Rammo
    Just had a set of ICON progressive fork springs put into  my 2007  Sportster 883 Low as well. Instant difference  in the ride and handling of the bike should had of done it sooner.
    Used the recommended HARLEY fork oil (type E)
  • sssmour
    sssmour
    I used Motul Heavy 20W. With that and the nylon spacer supplied by Ikon (instead of the piece of thin exhaust pipe HD use) it took that clunk out of the front end.
  • 666
    666
     yeah i put ikon pro. in mine the ride is sooooo much better might need to make the spacer bigger though after settling in any thoughts on that?
  • 48fan
    48fan
    good info thanks guys
  • terroristone
    terroristone
    Did you guys with the low suspension use the supplied spacers? because i cut mine in half and find its still very stiff! is it worth just taking them out?
  • terroristone
    terroristone
    Just an update to where im at. with the 50mm spacers installed i had 10mm rider sag, which isn't enough from all the info i could find. And being way too stiff i though i'd do some more research and see what i could find out. So i have came to the conclusion that you need tt have 1/3 to 1/4 of your total travel as your rider sag. So with these details i decided to remove the spacers all together as i only have 1/10. So with no spacers and only using the end caps as my preload i rechecked my measurements. i now have 23mm rider sag, that equals to in-between 1/3 and 1/4. the bike feels a little softer to static bounce. I'm yet to take it for a ride and test - dam rain.
    Andrew
    Edit : I just went for a spin and tried to run over as many bumps as possible, after removing the spacers it is 100% better. Seems to be good over all bumps and now i dont have feel all those little bumps/vibrations...braking seems to be good, i mashed the brake a few times and seem to want to pull up better, and dosnt dive as much as it did stock.....so far so good!
