fatbov vs supertrapp
  • brucecul
    brucecul
    i am ordering a fatbob and am wondering if anyone has fitted a supertrapp 2 into 1 yet /. and if so have they had any dramas ?  eg - scraping etc
    cheers bruce
  • brucecul
    brucecul
    thanks
  • Jam
    Jam
    Hi mate
    No probs with this exhaust scraping.  It all fits up just fine. .  The exhaust is pretty light compared to the stock pipes......so no need to run the bracket underneath off the crankcase.
  • brucecul
    brucecul
    well you've won me i'll order it tomorrow thanks a lot
     bruce
  • Firey
    Firey
    I am thinking a 2 -1 Supertrapp for my 09 Bob = Hey Jam are you happy with the pipes?
  • Jam
    Jam
    Hi Firey
    Pipe is good mate.  Fits to the bike well and is really light compared to the stock set up.  You have a options to run open/ closed end caps and discs to suit.  I have one in black and it is holding up pretty well paint wise.
    Not sure how it rates peformance wise against anything else as it would depend on complete set up.
    Mine has the following and seems to run pretty strong:
    Supertrapp (9discs/ Open end cap), Wood 408-44 with 4 degree advance, SE stage1, TTS with a Stix tune
    Cheers Jam
  • Firey
    Firey
    Thanks Jam
    I am looking at the prices now and will buy them soon
  • Harleyglide
    Harleyglide
    I`m a little late on this thread, but great choice of exhaust. No dramas what so ever.
  • Firey
    Firey
    I finally got around to buying them from M and M and installed them tonight, Its very quite!! I don't like loud, lets just say they will definitely go through rego!! my Mate was here helping and when we started it he was bagging me saying they sound like a VW they do!! I am ordering the open end cap now.
    Its good and light - seems good chrome and it all fitted up well, I don't think it will scrap either so I think I will be a lot happier in a week or so when I can hear it.
  • Jam
    Jam
    Firey
    Fit the Open End Cap and run 8-10 discs. (Open End Cap equates to 10 discs).  It will have have a louder sound.
    As the pipe gets older  (5000 + kms) you will find it will get louder and deeper..... just the nature of the packing inside it!!
    Stick with it mate it will come good........... Rather the note of these than the belly button exhaust.... (V&H Big Radz)
    Cheers Jam
  • Firey
    Firey
    Cheers Jam
    Good news, I think I am going to like them - I am doing some other work on the bike so I haven't ridden it yet - they are over a 100 mm higher than the standard headers and S/E mufflers so I will have to have it over to scrap these ones.
    Like you said they are a lot lighter as well.
    Thanks for the info Mate
  • brucecul
    brucecul
    thanks boys for your replies .
    need to know what sort of tuners are u using?????
    have a good weekend
    bruce
  • brucecul
    brucecul
    i havea big joes one i got off squeech in here still not sure if it is the best one to use .
    i got a dobeck in my 07 sporty
  • Firey
    Firey
    I am running S E P S T and when I was talking to my mechanic about these pipes, I asked him if I will need another tune - well blow me down guess what he said, yep just to be sure it not running to lean.
  • Firey
    Firey
    My bike goes heaps better with these pipes fitted, I live in the twisties and still no scraping! Dunno about if its running leaner - the plugs look the same - the exhaust looks its running properly for the klms that I have done - what else to look for Gents?
    I don't want to put it into the stealers for a tune unless I have to
  • Firey
    Firey
    Yes - I don't want it to run any leaner so I wanted to know any more signs I can look for - rather than plugs and the exhaust, which still looks ok for the klms its done - not many!
  • BURTO
    BURTO
     Oh yeah...............how bout a photo of the new pipes?????????
    Burto.
  • Noodle
    Noodle
    Nice explanation.. and helps me confirm some of the thoughts I've already had on these very issues...
    I've ironed out a lot of my tuneing based on these theories.. 'eyes, ears, smell' however my bike does not fart as much now..
