rear caliper 09 streetbob/ piston-seals
flea
the rear brakes on my 09 streetbob , always gave me the feeling they weren't, doing the job. on a closer look i found one piston very slow to move.[ i quess that both are to move together when the brake pedal is pushed down ] - so i remove the pads ,put a small block of wood in place, pumped foot pedal , seemed to take for ever for at lest one piston to move, pressing onto the block of wood ., the second piston started to move.,well after the first one.-- have orded a piston/seal kit hope it does the job. have any of you guys run across this problem, maybe even on other models
smeemn
Yeh had a similar problem on my front brake. did what you did and now it's ok.. go figure ??
