Online: John.R
fuel economy
  • taff60
    taff60
    Hi guys and gals, Ive recently picked up my first harley, a 04 Dyna super glide with a mikuni, hi flow filter and bluf turbo mufflers.  Love the bike to death already (swapped from a jap sports), but im not that excited about the fuel economy.  I only got 225 kms from the tank (main).  Im reading that i should be looking at 300 ish.  I realise that it may be me hitting the trhttle hard because i just love that sound, but i didnt think it would drop the range that much.
    The dealer listed that they had raise the carby needle one notch when they prepared it for sale, so I wondering if it may be that,
    I also notice that I dont need to use the choke apart from cold 5am starts.  In sunlight (20degs ish) it just fires up.
    What should i get from the main tank and any other suggestions ( the air filfer is clean.
    Thanks in advance
    Taff
  • smeemn
    smeemn
    225 is not too far from what I consider normal.try different brands of petrol. I put a fuel calculator in the workshop forum to help in this very situation.While your mates might be getting more miles I'm sure you'll be seeing them in your mirrors.
  • taff60
    taff60
    thanks pal. ur right about the mirrors, im VERY impressed with the off the line performance.  Its not as quick as my 98 ZX9R, but i can out drag quite a few japs and pull up hills that had my 9 dropping a gear.  Economy isnt my goal, i just wnt it running right.
    Ill try some shell fuel.  Im using 95 even tho the manual says its ok to use 91.  any sugestions.
    One things for sure, im never going back to jap.
  • stilllooking72
    stilllooking72
    I only get between 180-200 kays from my 2010 Wide glide, and I don't flog it either.
  • Gilbo
    Gilbo
    I usually get around 280 to 300km a tank, 250km if I give it a shit. Running Vortex since day one ;)
  • smeemn
    smeemn
    I've just started using Shell V power with great results. Carbys will use more fuel than injected.
  • fundi
    fundi
    2011 fatbob
    just filled her 16.5 ltr for 330 km on the odom
    running bp 98 oc
    work running and going hard on return trips
    20km per 1 ltr
    i only ever go for around 350 km then head for servo
    fundi
  • xcited
    xcited
    Over the past 5000 km my FXDF has averaged 5.74 L/100 km...
