Online: John.R, Stuart
gearbox problem
  • smeemn
    smeemn
    Does it actually go in neutral or does the light come on.If only the light comes on then it could be a faulty neutral switch.?
  • sparrafatboy
    sparrafatboy
    light works fine,its as if it gets stuck in between 3 gear and 4 gear when coming back down
  • smeemn
    smeemn
    What happened to spalding1965 ?
    Looks as though you'll have to strip the box and have a look in side.Everything else would be a guess.You can take the top off and look inside.keep us posted cheers.
  • sparrafatboy
    sparrafatboy
    i stuffed up username had to get another one
  • sparrafatboy
    sparrafatboy
    been looking at after market gearbxes,revtech ultima achd or should i fix mine
  • angry
    angry
    take it to a dealer and get your shift adjustment checked
  • smeemn
    smeemn
    Sparrafatboy how's the gear box problem ???
  • sparrafatboy
    sparrafatboy
    not good,gearbox still neutralising inbetween gears.i have a 113 cube s&s motor in it,wondering if the extra hp may have caused the problem.
  • smeemn
    smeemn
    You'll have to open the box and take a look.The gearbox can take the horse power.If you shifted gears under load you could have bent the selector arm.
  • mirkin
    mirkin
    check your linkages arnt a bit stiff and stopping the gear box armfrom fully returning between shifts.
