Hi I am in Mount Gmabier South Australia and I am chasing the lend of a clutch tool to press the retaining plate(not the correct name) on while i put the split pin on. I guess if I cant lend one for 1 night does anyone know where I can buy one also as I have limited mechanical klnowledge are the jap bike ones a similar setup?
Thanks in advance
Tool Needed.................whole bunch of the buggers in here!
[sorry to hijack the thread]
I guess i did leave that one open a bit.
The motor is a current 127" Ultima, the tool pulls against the clutch spring so you can put the circlip on. Threaded bolt in the middle and 3 jaws to grap on.
Ahh good old ebay thanks for that.
