tc88 gear oil
  • gringo
    gringo
    gday all,
    is shell advance lightweight gear oil ok in my gearbox? its 10w  and suits up to 75w-90 apps. also put penrite sin 10 10w-70 in the donk and auto tranny fluid in my primary.
    bit worried my gearbox oil is to light, shouldve maybe used 80w-140???
    thanks
    gringo
  • robcig
    robcig
    I use Redline Shockproof. Have done for a while and my bike loves it. Gear changes are smooth and she does'nt clunk as much,
  • CHARLIE
    CHARLIE
    What you are useing is fine just change to full syn 75w90 gear oil ATF  in the primary is good,try Redline high temp ATF it is terrific.
  • smeemn
    smeemn
    Mobil gear oil for me
  • gringo
    gringo
    cheers men.
    keep bringing it people i'm all ears.
    thanks again
    gringo
  • V2Evo96
    V2Evo96
    I run a good quality GL-5 spec 75-90 in the tranny. I don't stick to a specific brand, but only quality brands are considered.
    I too use HD formula + in the 09 BargeGlide Primary, but have run ATF in the EVO successfully for years. Never heard of compensator issues in the EVO engine, but there are plenty of issues with the later model (09 and up) compensators. Come to think of it haven't heard of problems with the 88's either.
    Not so sure 'shear' rating of the fluid is the problem, rather the lack of channels in the compensator shaft to provide access for the fluid to properly lubricate the moving parts. Sorry for poor explanation. Plenty of info on this issue on the stateside boards.
