Hi Guys
I am thinking of putting a wider front end on my 93 lowrider but i want something that bolts straight on. Does anyone know if Dyna Wide Glide or Softail front ends of the same years bolt on with no modifications ?
Cheers Potluk
Potluk, I used one of these guys wide glide conversion kits, came with everything from spacers for the fender to disc spacers. Worked a treat although I didn't install it myself. Just another option. You will need a different headlight becasue these are bottom mount trees but I got one from them for $39 and my existing lamp went straight on to the new headlight.
vulcanworks.net/39mm-Wide-Glide-Triple-Tree-Conversion-Set-Chrome-p-256.html
vulcanworks.net/Bates-KD-Bottom-Mount-Headlight-p-456.html
