Online: Merv
Swap tank decal
  • brickmark
    brickmark
     Hi,
    Just got a 08 Super Glide Custom all good except I am not that keen on the tank decal.
    1. What would it take to remove excisting tank decal and replace with a Fat Bob  - ie the HD insignia?
    2. From what I understand the 08 FXDC, FXDWG and FXDF tanks are the same size. Are they the same shape/tank?
    3. Know of any online shops in the US that sell tank decals for HD?
    Exsisting decal
    Fat Bob decal
  • Gilbo
    Gilbo
    Gday Mark, try eBay for you tank decals mate. I see a shit load of Fat bob badges all the time.
  • brickmark
    brickmark
    Cheers Gilbo - found some used for $120. Will keep and eye on eBay to see if they come up any cheaper.
  • smeemn
    smeemn
    1 . remove very carefully with a bit of heat (hair dryer) and fishing line.wipe whats left with mineral turps use sparingly.
    2 . yes they are the same.
    3 .yes you can buy them.
    4 .yes there are lots of places you can buy them.
  • brickmark
    brickmark
    Thanks Smeemn,
    My mate rides a Honda he will have a hair dryer.
