Doc's Tuning Guide
  • AJ56
    AJ56
    I have been reading Doc's Tuning Guide for the TTS.
    Something I have noticed is the difference in what it says in this guide compared to the TTS Tuning Guide. Some of things that I noticed is
    Set the PE table to 13.5.
    Set the Warm-up Enrichment to 0??.
    Set the Adaptive Knock Retard to 0??.
    Disable Knock Control in Tuning Constants.
    The rest is the same as per normal.  I thought turning off the knock control and retard would be done after Vtuning to check for those issues once you have developed a map. It is a more consise instruction than what is in the guide.  This was also written before the Auto blend option was brought out with the TTS.
    Here is the link if anyone is interested www.v-twinforum.com/forums/attachment.php
  • AJ56
    AJ56
    Mate your a rocket Scientist
