Hey Guys,
I have an Anniversary Super Glide. It came out with rims with no lumps at the spoke holes or seams around the edge. There is a name for them. I don't know it but. In 06 there was an after market 21 inch rim the same for Wide Gliges etc. Does any one know of one floating around somewhere? And if I remember correctly, the blocks to widen the rim can be removed. Don't know for sure though. Thanks in advance.
Jeff
Sounds Like my front Rim. see avatar.
It still has signs of corrosion (chrome starting to lift) where the spokes enter the rim and rust on the spokes. I've taken to spraying the entire rim and spokes with WD40 after every wash to ensure additional corrosion is kept at bay. WARNING. dont get WD40 on the brakes. wrap up the disc and caliper in a plastic bag prior to spraying and wipe over the disc with a "brakeclean" soaked rag after.
My bike was a second hand bike and carried the corrosion from the previous owner. Since I have statred this after wash treatment no more rust or chrome lifting has occured.
Hey Wayne,
I'm after the whole wheel. Can you get me a close up photo?
Cheers Mate.
