TTS HELP PLEASE
  • DarrenO'Donnell
    DarrenO'Donnell
    Hi guys just wondering if anyone can help me out, I'v got an 06 Night Train (oct 05 build), I'v just put a 98" (1605cc) big bore kit through it,andrews 54h cams, screamin eagle heads.. It's got V&H 2 into 2's and a hypercharger on it. I can't seem to find a map to suit it.. Also I noticed that you need o2 sensors to Vtune it, will I get a good enough tune of just a map or would I be better of cutting my losses and buying a power commander? I'm in Bunbury and no one down this way has a clue about anything other than the power comm..
    Cheers for any help
  • 2005 FLSTFI
    2005 FLSTFI
    Darren
    Put the O2 sensors on my 05 fatty to V-Tune with TTS. It is not hard at all.
    To start with get a wiring loom out of a wrecked car & use any of those wires, preferably pink & black, if not doesn't matter.
    Order the sensors, pins yellow seals & whatever else from M&M cycles & your ready to go.
    Does your exhaust have the sensor bungs in it, if not get some of those from an exhaust shop & get them welded in.
    It is a bit of task to do all this work, but believe me it is worth it with all the results at the end.
    I am happy to guide you through it if you need help with it.
    If you need those part no's for seals, sensors etc I can post them up for you
  • DarrenO'Donnell
    DarrenO'Donnell
    Thanks guys its good to know I can put the o2 sensors in it.. Any ideas on maps for the meantime so she runs properly with the new build??
