Online: John.R
Pipes for Deluxe
  • Gloved1
    Gloved1
    Hi all, just bought a standard 08 FLSTN and am looking at pipes. Is it as straight forward as buying and fitting, or are there other considerationseg air cleaner upgrade etc. Was also looking at a hypercharger at the same time. Advice would be appreciated.
    Also I am looking for some highway pegs that I saw on another bike, they were just like an oversized moustache as opposed to crash style bar. I have been looking but have yet to locate them. Any advice would be appreciated
    Tks Gloved1
  • jacks
    jacks
    Ebay under Harley softails
  • percy
    percy
    Gday Gloved1,     Ive got a 2010 deluxe and went with air cleaner upgrade and v/h pipes from dealer before picking the bike up..runs great
  • Gloved1
    Gloved1
    Thanks for that. I think I have decided on a set of Rinehart Cross Backs Chrome Flush with Black tips. Also ordered the Pro R Hypercharger. Shopped around last night and found best price with shipping seems to be MandM.
  • rowie
    rowie
    Hi Gloved1
    I have the type of highway bar I think you speak of. They are kuryaykyn moutstache bar. Think there are 2 types, adjustable and not. I have the adjustable ones, and bought pegs to suit.
    see link below
    http://www.kuryakyn.com/Products/565/Adjustable-Mustache-Bar
    I was going to get them from M&M Cycles in the states, but a fellow forum member (Walka, based at VPW in Epping, Vic) did me a good deal. send him a pm.
    I find them good to use, but a bit fiddly to fit and get squared up but not too bad. Only thing to be aware of is clearance bewtween heal and rear brake lever, and clearance from guard for when cornering if hit a bump.
  • Poddy
    Poddy
    Hi mate , have a 06 FI and run an open a/c and touring pipes. Was running Rush but found them loud and loss power
    Went back to the H-D pipes and the bike has all the power back
    Get what ya like, big range
    Poddy
  • keith
    keith
    Gloved 1 do you still have your stock pipes ? Would you like to sell them ?
  • Gloved1
    Gloved1
    rowie,
    I purchased the very same or very similar along with the pipes and Cleaner, just not sure mine has as must bend length??.
    Kieth, at this stage I have a shed full of parts ready to go on my new bike. The bike itself is on a ship somewhere between America and Australia. I expect the bike in a about 6-9 weeks as once it lands it has to get cleared and then complied and then it will be mine so want have the factory pipes until then.
  • keith
    keith
    Thanks mate i'm doing the same I have bought a 09 Deluxe just Nth of LA,going over in 4 weeks time to ride 22 states before June 1st when I put the bike on a ship and send it home the Deluxe I have bought has V/H long shots on it now and need the standards to get it compliant here in OZ.I have been given a set of standard pipes in the US but there are of a FatBoy not sure if they fit but I will still bring them home along with any out bits and pieces I can get at the right price.Good luck with your bike Cheers Keith.
  • Gloved1
    Gloved1
    Kieth,
    I will certainly let you know how I go and if you need them give me a yell as I would certainly hope by June mine will be complied and rego'd, and have the reinhard units fitted.
  • keith
    keith
    Who is bringing it in for you? I havent got down to that as yet i've visited Geezers and QLD imports website and made contact with Chopaweeza via email found Wayne on the Forum,Any tips you can pass on ? Cheers,
  • Gloved1
    Gloved1
    Dealing with a company called Californian Image. Will send you a pm
  • keith
    keith
    Thanks for the info,Have PM for you.
