Online: Humbug, Hilly, speedzter
Wet weather tyre pressure
  • Mainey88
    Mainey88
    Watched a bike go past me today down the freeway while it was pissing down with rain and looked at his back tyre, very little tread was actually in contact with the road (only a skinny bit in the middle) naturally this would be the same in dry weather but the question is if your tyres were let down a bit for wet weather would it give you more tread in contact with the road therefore more grip
    I've never mucked around too much with tyre pressures so I checked the rear on mine and its only 28lbs, I'm going to Frasers in the morning and its going to be wet and wild   so just wondering whether I should leave the pressure where it is or pump it up to 36lbs
  • 05 FXDX
    05 FXDX
    Leave the tire pressure the same as dry riding, the front tire is doing all the work dispersing the main volume of water. If you lower the pressure you'll have a greater chance of aquaplaining.
    When riding in the wet be smoother on the controls and you'll be surprised how much grip you have.
  • Paul.C
    Paul.C
    Mainy,
    28 is to low, that's the pressure I used to run on a track bike.
    32 front and back is a good general pressure.( that's what I run )  If you go 2 up and gear I would go 34-36.
  • Mainey88
    Mainey88
    Thanks boys, wacked the pressures up and rode home in howling wind and rain yesterday from frasers and got soaked, had to keep dodging the cagers pulling out in front   am i now inducted into the SWWRC................................southwest wet riders club.
    Tyre pressure are now on my to check list every couple of weeks.
  • Paul.C
    Paul.C
    Thruster,
    your photo should be banned from HDFA
    Mainey,
    What pressure dd you end up going for ?
  • andij
    andij
    yeh thruster the brokeback mountain motor cycle club could be watching you............
