V+h to stock
  • yelladawg
    yelladawg
    Gidday all. Had vance and hines straight shots slip ons on 08 dyna. Got pissed off with noise. Took off V+H and put on stock de baffled pipes. The bike was dynoed for the V+H will it be alright to leave pc111 tuned for V+H and run around with stock pipes. Was told the pc self tuned and all will be ok. Bike seems to go ok lost a bit of grunt but runs way smoother. Dont want to damage motor any advice?
  • yelladawg
    yelladawg
    I will find out. Thanx.
  • jacks
    jacks
    Did u try the quiet baffles in the straightshots, they take 3 db's off but give a great note, quiet around the blues and angry when giving grunt...worth a look..
  • yelladawg
    yelladawg
    Thanx for the advice. Its always hard to get a straight answer.Everyone gives advice after 4 pints but hey how reliable is that?I am staying with de baffled stok for a while till I can sell the V+h slipons then will use the cash to get S eagle street legal or S+S slash cuts. Then I guess its off to the dyno man to be ripped another $300 bucks. But hey all worth it when you out there floogin the old girl. Cheers Ian FXDC.
