Oil light.
  • Ynot
    Ynot
    Howdy,
    Got a possible problem with my Streetbob.
    When it has been parked up for a while and I start it, sometimes the oil light stays on longer than it should. Like 4 or 5 seconds.
    It never comes on when riding, and yes the oil level is fine. I'm using Mobil 1 V2, and a K&N oil filter.
    Is this a sign of impending doom, or just one of those quirky Harley things?
    The light used to go out as soon as the engine fired, just recently started doing this. I'm guessing maybe it's the pressure switch, I tried pulling the wire off and cleaning it up, but made no difference.
    What do you guys think?
  • smeemn
    smeemn
    Mate I don't think its anything to worry about.Takes a bit of time to build up pressure.If you put a pressure gauge on it  you'll be amazed by the variation of pressure on different days.
  • Ynot
    Ynot
    OK, cheers. Might pull the switch out tomorrow and give it a clean.
  • Evo
    Evo
    Probably the easiest fix is to ride it more..
  • Evo
    Evo
    That makes it harder.  If I can help you out by riding it for you, let me know.  I promise I will only ride it around the block.
