K&N Air cleaners on Sportser
  • 308bever
    308bever
    they look pretty good, a little hard to believe that you can get 8 horses from a filter change though. would that include the need for a computer program upgrade at an extra cost too?
  • SJ
    SJ
    Only 4.4hp increase on the 883, but would assume they meant with the programing to match?
    That was my main thing... Ive added better pipes, and if I was to get the K&N filter, I assume it would run fairly rough without the program change? Backfire or pop?
    Just want something that looks a bit different to the big SE spike, but want to know it will have the performance/ life of HD stuff (hope for more of both)
    Any help appreciated.
    SJ
