Hi all,
Just a quick one...what is the general cosensus with braided cable/lines ??
Is it best to go standard stainless braid(or do they frey & hard to clean)
OR, best to go ones as above but with plastic clear sheath covering (or does the plastic discolour & go milky over time??)
Any thoughts or ideas much appreciated. Bikes going in on Tuesday.
PS: one other ?..do you go 2 inch over forks when installing 5 degree raked triple trees or leave the stock fork tubes ???
yep there is plenty of crap cables out there and plenty of good . yes the clear coat can turn yellow on the crap ones i have even pulled them out the packet starting to go yellow the last set i put on 6mths back where motionpro stanless braed clear coat of fleebay and are still like the day i put them on nice smooth cable operation and fitment was spot on easy to keep clean chrome fittings arnt rusting yet eather and i would use them again if i have to my 2c worth
sunblock ? i pamper my bike enough now fucked if i am going do that i have a brand new speedo cable made by vtwin in the packet on my wall and the clear coat is going yellow ,and i have had thorrtle cabels from debrix go yellow in 6mths
