Online: B0nes, Rextheute2022
Buell Project
  • vulcan2509
    vulcan2509
    Hey all, pretty new here. I've been thinking of doing a hard tail Buell. However looking at the forum I assume it'll be classed as an ICV. This being the case will it be easier to get through the compliance process if I were to leave all the running gear as Buell, all I will change is the frame and tins. should I bother or is it gunna be too much hassle.
    Thanks
    Eddie
  • wayne.craft
    wayne.craft
    If you can get a cheap doner Buell and keep all the running gear it should make the process a lot easier, the hard part will be dealing with the dicks at RTA with the ICV paperwork..... You going to use the Jig or buy a frame Eddie ???
  • vulcan2509
    vulcan2509
    Might use your jig :)
  • vulcan2509
    vulcan2509
    These frames I'm looking at are top notch even though they are American MSO's and all that.
  • wayne.craft
    wayne.craft
    Eddie check out bikes for sale Fat Tony has a nice Sporty to go .....
  • wayne.craft
    wayne.craft
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=8&postid=302870&view=topic
    Here is the link Eddie, I think it works ive never posted a link before ???
  • fastapastor
    fastapastor
    have you got a buell front end for sale?
  • vulcan2509
    vulcan2509
    Sorry fastapastor I haven't puchased the donor bike yet just checking if it's even doable first
    Chppaweeza I spoke some time ago to Peter Smith engineering and he's right off doing anything with bikes, can you suggest another engineer in the Castle Hill area who may be up to the task.
    Thanks everyone for the input.
