Plan to smoke/ tint indicator lenses on my Iron883, and know that on previous models you can either buy tinted clear lens and put in colored bulbs (which crap out). Other option to do it was the way I used to years ago when I was a painter - Use 2 pak clear with a few drops of black and spray the standard colored lenses.
My question is about LED's which I know little about.
My '11 model has LED indictators AND colored lenses. I was under the impression that if you had LED's, you could have clear covers (or tinted clear). Just trying to figure out if I can order some tinted CLEAR lenses, or should tint my stock COLORED ones.
Any help or hints appreciated.
SJ
iv'e had orange globes on my bike for four years with no trouble .good luck which ever way you go .
hi sj yeah i put mini leds on the front and wanting to change rear lens, might be near sin city tomorow so ill check em out
Cheers guys. Yeah the idea was to hopefully leave em stock and just change over the lenses.
Also had a few people mention VHT nightshades spray to tint the stock lenses (way darker than smoked when dormant/ retains original colored lense when in use).
Let you know how I go. Thanks again.
If you could let me know Aleister Crowley 666 that would be great. I have some mates in Currumbin that could probably grab em for me.
Cheers old boy
