Online: John.R
Problems with 2011 48
  • Harleyade
    Harleyade
    Has anyone encountered problems with their new 48? after 202km, my speedo and odometer doesn't work. Needle stuck to 0 and odometer stuck at 202. The automatic signal off also not working. Very disappointed with it. So i got Harley to pick it up from home and send it to Fraser Concord.  Please share your thought....
    To me just sounds like a speedo problem. take it back they will probably fit new speedo.
    Just wondering if these bike's are now assembled in India?
  • melb-ourne
    melb-ourne
     Ya... had my clutch burned out at 600km. Had to call harley assist to tow my 48 to the dealer. Apparently i had to check there is 10mm free play on a clutch lever.
  • 308bever
    308bever
    more info, how do you burn out a clutch that quickly????
  • Clement
    Clement
    so is this warranty or user issues - user pay?
  • 308bever
    308bever
    is it getting fixed under warranty?
  • watto883
    watto883
    my 2008 sporty speedo stopped working on and off twice ... diagnostic fault came up ... they reset it and it was sweet ... getting ya money back seems a bit of overkill .....
  • Harleyade
    Harleyade
    Got it back this morning and they say that its loose cabling inside..i suspect it's more than that they just want to cut it short in the explanation department> Next project will be new exhaust..., AC and fuel pack.
