Are softail rear shocks rebuildable??
  • Burnzi
    Burnzi
    And if so is it a hard job, better to replace with new, other options or a link to the thread that is bound to be on here somewhere?
  • Burnzi
    Burnzi
    I should add old softail as in 1987, not those u-beaut newby ones
  • smeemn
    smeemn
    I dont think it would be worth while re building. Shocks that old could have fatigue cracks. I'd put my money into a new set.
  • Burnzi
    Burnzi
    mmm good point.
    I geuss you have a few choises. Cheap Replacement ones,,, I sell Oil Filled for $200.00 a pair or Nitrogen Filled for $299.00. I can get you Progrsive for around the $650.00 mark or Ikon can rebuild your for around the same amount
  • groover
    groover
    To my memory I don't think they are.
    Alot of softail owners back then would just go and fit a pair of froggy fournales as the originals were poor quality
