Online: HD17
Advice on street Bob handlebars
  • Train
    Train
    Hi Fellas,
    I'm in the middle of putting som 16" apes on the Street bob. (integrated risers).
    The bars are 1" and when i sit them in the risers, they cleared the fork tubes by about 1/2 a mm. When i tightend the risers, the bars then just touch the top of the fork tubes.
    My questions is, will this be ok. I know i can drop the fork tubes to get that mm clearance, but do i need too.
    Just want to know if i'll have any problems.
  • spanners
    spanners
    my guess is it will probably send a vibe up the bars that ya wont like. Bars naturally flex so give 'em the room.
  • Train
    Train
    Cheers spanners, i thought that might be the case.
    Choppaweeza, the street bob has risers built into the triple tree, so i think my option will be to lower the fork tubes a mm or so.
    Is lowering the fork tubes as simple as loosening the bolts on the triple trees and tapping down? How do you know if you've lowered each side exactly the same?
  • Daggs
    Daggs
    lower them in the trees a bit, they are generally up a few mill anyway so just drop them level with where the round section of the cap meets the hex of the cap
  • Train
    Train
    Thanks fellas
