G'day all,
Old mate got a puncture on his trumpy the other day in the middle of nowhere - so I continued on to Pemberton and got them to come out with a couple of plugs and a compressor.
Now they say a plug is only a temporary repair and the tyre should be replaced asap. This is a near new $300+ tyre so whats the general consensus? Shell out for a new tyre or keep riding on the repaired one until it's worn?
I know what I would do if it was on the car - just keep using it, I have in the past with no problems, but unsure about bike tyres - never had to plug one before...
cheers, stumbly
I plugged a near new tyre on my FLHT and promptly forgot about it untill I worn it out and replaced with a new tyre. The changer asked me when I plugged so I told him (14000km) and he said they often see them as nobody buys new tyres if they do not leak.
I am running with 2 plugs side by side in mine and have done for about 9 months now with no problem. In fact I just got back from a run down the coast to Batemans bay with no issue whatsoever, still the same pressure when I got back as when I left.. The reason there is 2 side by side is, I had a flat piece of metal about the size of a points file (for those of you who actually know what one of those is!) put a slice right through the tyre, and because it was a wide hole one plug would not seal it, so, I put another plug next to it in the same hole, and it has been working great, I check the pressures regularly and there doesnt seem to be a leak or anything. IT IS A REAR TYRE THOUGH, NO WAY WOULD I RISK IT ON THE FRONT!!!
yes I know what a points file is. Damn that grey hair it gives me away.
Russ
