Online: B0nes, Rextheute2022
tank lift pics
  • Deadwood
    Deadwood
    Can't help with photo's mate as I took mine off but after recently replacing the trees to a wideglide setup the inside of the top tree would hit the top of the lift kit bracket on both sides reducing my turning circle which ain't much fun with ape's. Just something to look out for. I bought mine from eBay.
  • evilsim
    evilsim
    Gus here is a pic ... mine has a 3" lift the other has none.
  • wazza-in-oz
    wazza-in-oz
    Humongus is that your bike in your avatar?  If so it looks awesome..... can you post up some bigger pics so i can get a better look at it.
  • BURTO
    BURTO
     Try takin out the front tank bolt and loosenin the rear one. Then chock the front of the tank up to the height youre thinkin of with a block of timber or whatever..................then stand back and see what you reckon!
    Burto.
  • lucky
    lucky
    hey guys , might sound like a dumb question , but given the fuel feed is more to the front of the tank , wouldn't the distance travelled be compromised due to the fuel being forced to the back of the tank . just a thought ,
  • codga
    codga
    put a 2inch lift on my FXD awhile ago,makes it easier to clean the rocker covers ,milage the same but the low fuel light comes on earlier.
  • 883n Harley Convert
    883n Harley Convert
    Got a two inch lift kit on my Iron, haven't really seen too much of a change in km's......................like the look, it gets rid of all that plastic rubbish above the rocker covers on an XL.
