WHITE WALLS
  • condor
    condor
    what is the best and most effective way to clean white wall tyres
  • Hound_Dog
    Hound_Dog
    Bike lift is a must have also.
  • Herby
    Herby
    I had good results with white jif on a chux's cloth
    Do a small section at a time , have a bucket i=of water and a sponge handy to wash off , then dry it of and repeat till comes clean
  • keith
    keith
    Bike jack a must have, pot scourer with jif or white king bleach.Dont let grime build up do twice a month works a treat.
  • DocWilson
    DocWilson
    HD wheel and tyre cleaner great stuff
  • jacks
    jacks
    I use ajax,scourer,bikelift and scrub like buggary....prick of a job as the venoms are ridged where the metzlers are not...prefer the venoms though...cheaper than harley shit... (ajax and scourer that is)....
  • Poddy
    Poddy
    Presole and water - quick and the best
  • one_oak
    one_oak
     best cleaner i found was a clean rag and some kero. Takes about 2min each wheel, need to use a new rag for each wheel depending on the size of the WW.
  • Bitza
    Bitza
    Ive found that after cleaning a quick wipe with a silcon spray on a rag and a wipe of the whitewall, avoid running surface and next time round the cleaning is easy work.
  • fathee01
    fathee01
    Give gumption a try with a non scratch scourer;works for me.
  • IK
    IK
    Wet & dry sandpaper
