taking vids on the cheap !
  • russ4570
    russ4570
    Fucking awsome. nuff said.
  • shovelhead1
    shovelhead1
    awesome mate , how much filming can ya get on 8gb card
  • AJ56
    AJ56
    For $50.00 that is bloody brilliant.
  • Deadwood
    Deadwood
    Vid was shidot Crusty. Where'd he get the glasses from?
  • Deadwood
    Deadwood
    Cheers Crusty, just bought one.
  • stumbly1
    stumbly1
    yep, I'll be getting a pair aswell - cheers cob.
    Ya mate doesn't fuck around with those bulls eh? see the buggers still trying to have a go even strapped up!
  • Canbro
    Canbro
    Gutsy dude! I initially assumed he was in a bull catcher not a quad. Great picture quality, especially considering the terrain being covered. Gotta get some...
  • Robbo_Townsville
    Robbo_Townsville
    Bought a pair and they work fine. Resolution is good, comfort good, the only prob I have found is the remote.
    They will record when the remote is pressed but the will not turn on and off from the remote. Problem being they will turn off after 5 minutes if they sense they arent recording to conserve the battery.
    Which means you have to take them off whilst riding, turn them on ( look no hands mum) and put them back on.
    No great dramas, but when you and your mates hit the twisties you have to either pull over or run the gauntlet to turn them on to record the footage.
    Other than that they are great. $100 from flea bay for the exact ones used in the above video.
    Robbo
  • Deadwood
    Deadwood
    Bought a pair as well, remote works fine for me but I think the resolution is pretty ordinary. Wasn't expecting much for the price of them but would recommend High Def ones if you would like some proper video. Bit jittery but that could be a combination of both my lowered rear shocks making for a pretty rigid ride and the Pacific fcuking motorway along the Gold Coast section.
    Sample attached;
