I only use cometic now, few years back i seen a guy have a problem with a James head gasket was told they changed something with there head gaskets. the guy was doing a long run & the new James head gasket failed.
another reason why i like Cometic three peice is it is possible to reuse them.
but the rest of the jame gaskets are fine its just i would not use there head gasket personally.
the three peice Cometic i have is part copper thats why they say can reuse.
hi, i think james use's the MLS steel head gasket's cometic style now , these head gaskets have been improved upon since the 90's , can have cooper head gasket's made here what ever thickness you need @ associate gaskets man co marigold st revesby, A machined fire ring grove or o'ringed is best used, would not re-used any cooper head gasket with-out 1st anealing( i think i spelt that wrong ), cooper goe's hard when worked over , in proddie 883 roaring sportie's we use too re-use the stock shit fibre head gasket's so we could have more squish with-out cheating, the gasket's would squash out thiner with more use up to 7 times, , for the gagket's to last do not rev hard when cold ?
