anyone using this
  • lucky
    lucky
    no  , i use the harley synthetic oil , do you notice a difference with your oil ,iv'e got no complaints at this stage .
  • speedwobble
    speedwobble
    Yes, been using it in my EVO and Shovel  and most of my other bikes for years was Omex before Fuchs took them over no problems and great oil,doesn' t thin out like water when really hot as some other oils do. You need to let your motors warm up before before getting up it as it is a thick oil.
  • bertiebettle
    bertiebettle
    Fuchs do make a VeeTwin Oil that they recommend for harleys. Looked into a while ago have not try it yet.
    I have used fuchs diesel oil, very good has seal conditioner in it. stop a dripping rear main seal.
