I had a crash on my 2010 sportster 1200c got hit by a tarago van just got out of hospital there was more damage to me then the bike the front has damaged forks wheel and triple tree looking at geting new front end wide glide front from demond cycles they say front end fits on sportster did any one buy this kit it seems to good to be true because of the price brand new $654 with free delivary the kit comes with
Complete Sportster®, Dyna®, FXR, Wideglide® Conversion.
WITH '60 SPOKES' CHROME CHOPPER RIM Take off your complete narrow front end and turn your bike into a chrome bad ass wideglide. Why buy a 35 or 39mm conversion tree that does a half-ass job? Just sell your narrow set-up on Ebay for $500-600 and buy Our Set.
This is the real deal billet aluminum triple plated chrome Wideglide front end with chrome 21" 60 spoke front rim or for extra $50 you can have 80 twisted spokes chrome front rim.
Hidden Chrome Axle and Wheel Bearings Included.
Fits any Harley-Davidson® Frame with 1" Neck and Custom Application.
All components are Brand New in the Box
Price is too good to be true, you'll find they do charge delivery overseas for starters probably doubling the cost. Mixed reports on demons quality on US forums, some say its okay, some say its rubbish, don't recall reading it was great. It's most likely chinese made as most their parts are, but then again a lot of your bike already is anyway. Freight on big items from US is the killer using usual couriers, if you organise the 'free shipping" to a mob that fills containers would work out cheaper. Do a search for demons on hdforums.com or xlforums.com.
The Front End in the Photo is of a Midwest / Ultima 41 mm Softail Front End with a Cheap 60 Spoke Wheel. Both made in China and will not go straight on to a 2010 Sportster, You need a Inturnel Fork Stop Kit and a Pre 99 Brake Cailper to make it work. I use to sell the Tripple Trees buy have a lot comming back with the Chrome flakeing off after a few months. and Demond Cycles are a Dog of a Company, I get lots of Guys that have bought stuff from them and all had problems, Thats why their in my Shop getting their problems solved. There is nothing on the Market to replace your stock Front End. All After Market Front Ends are made to Pre 99 Soft Tail Spec. You can get them to go on Sportsters but you will find your self having to get stuff made by your local engineering shop to get it to fit up. It can be done but it's not that sraight forward. If you set on fitting something like that on the Bike drop in to the Shop and I will show you whats involeved. other wise keep a eye one Ebay there is alway Complete Sportster Front Ends poping up
I thought that they where to good to be true I had a look around on the net everyone say demond cycles are shit thanks for help i am looking at the rocker front coz it is inbwteen narrow and wide glide i think it would look good any one fit this on new sportster
Please do not buy anything from:
Demon's Cycle Inc. 1407 SW 10th Ave. Pompano Beach, FL 33069
Main phone line: 954-943-0000 Fax: 954-943-0377 Email: sales@demonscycle.com
before you search your sister forum (HDF USA) for many hundreds if not a thousand threads/posts concerning this company. I live/work within 20 miles of this place. Please read before doing anything. If you wish info on a front end, I live in the USA and could provide insite on what you could do. I work in suspension and my scope does not include what you would need. I have no problem in helping you out. Look in the classifieds in the HDF also. Those guys generally will give you a fair shake.
A 2010 has a 31 1/2" set of forks to Center/Axle. You can use a 39mm, 49mm, XR1200 inverted fork, Ohlins, or a bad choice is a 41mm(1 5/8"). The forks and triple trees of a Dyna will fit with knowing what the differences are.
